Only Mod i want.
(In Topic #77303)
Only Mod i want.
I'd like to fit central locking, has anybody done this using the cheap kits on e-bay or can you suggest another supplier.
Thanks.
Try to find something similar
rgds volkswarren
Regards Volkswarren
I bought a 4 Door kit and linked the boot lock in also. As mentioned you will need to remove the door cards and attach the motor then run the wiring thro the door and under the dash. I mounted the control unit under the dash next to the fuse box, for easy access.
It really is simple and most come with instructions; if I remember correctly the solenoid (the bit that moves the lock up and down) I mounted on the inside of the door in line with the locking mechanism to prevent any visible holes.
I then run the 3rd door kit to the boot under the carpet, the 4th i just just out of the wiring to keep things tidy.
Hope this helps
I have a good alarm, I'll try an Auto Electricians for compatable kit.
Here is me trying to get my blowers fitted and now I'm obviously going to get remote central locking fitted!
I just want to say its all your fault!
Only kidding mate, catch me on msn if u get a min got a quetsion for u.
