o2a gear shift mounting
(In Topic #106055)
sorry to ask this coz you've probably been asked a thousand times, iam fitting a 2.0 abf engine & o2a box into my mk1 cab, just need some advise on mounting the gear shift housing & cables, does this need to be mounted in the car, or can it be fitted underneath. any pics would be helpfull
i will let you no how i get on.
thanks again
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
I've been using tin snips but they are not quite beefy enough to get through thick stuff like that.
looks good tho
ill be cracking the welder out soon to do some o2j mounts hopefully if i can find a cad drawing or measurements
1989 caddy
1981 gti
1993 cabby
1981 gti
1993 cabby
Cheers for the fabrication/selling comments but everything for the car was made bespoke, and the templates thrown away. You'd need to cut the large hole and weld in any tray "manufactured" by someone else, and as far as I know most welders are also pretty good at fabricating things too, etc. So I can't really see a market out there. There's a bit of a market for "bolt on" stuff (like engine mounts for 02A) but not really "weld in" stuff.
By all means if you're local to me and want some welding/etc done, then maybe I can help out people?
as they cost naff all to make and i hate seeing people getting there trousers ripped of by people making a mint from them
bens_cab said
im going to ge a handle of the 02a mounts and knock a few sets up and sell them for a few quid ie ?50 a set
I might do that "VR6 kit". At ?12,000 a pop, I only have to sell 2 a year to make ends meet.
Just making up a little pedestal type of thing to sit the gearknob on, then the cables running in the car then through the bulkhead?
Chris
