need help with golf conversion!
(In Topic #109477)
So have you wired up the 16v ignition control?
Richair
83' GTI 16v roadsport
96' BMW 328i Touring
90' HF Integrale 16v B-road slag Sold!
98' Honda ITR #1775 Sold!
89' GTI 16v Sold!
91' CRX 16v trackslag RIP
89' GTI 16v Sold!
Sted_09 said
all the wiring is done it will turn over but no spark, the coil is live but there is no live comin from the coil lead
Can you clarify what you mean by "the coil is live but there is no live coming from the coil lead"? There's 3 connections on the coil, for a start….
Basically, can you explain which variation of ignition wiring you have done, and what is connected to what, etc. There is a feint possibility the wiring is correct but one of the components is faulty….but no way of knowing before the wiring is investigated.
Sted_09 said
the lead to the distributor is not live were as the leads 2 the coil are a dunno if that makes much sence or not
How are you testing if its live or not?
Sted_09 said
using a 12v tester and the coil becoms live wen turnin the engine over
Well, the king lead is about 10,000V, and its a very short pulse, so it won't show up on a multimeter, or it will blow its electronics inside, or it will short out through your hand instead of the multimeter and give you a nasty shock.
You need to test for a spark by putting a spark plug into the end of the king lead and holding it with a pair of insulated pliers, with the thread of the spark plug touching against a sound earth point. Or by leaving the HT leads connected up and using a timing light.
If the ignition is on, you'll see a steady +12V on one of the coil connections and an intermittent (1 per 180 deg turn of the crank) on the other one. Can you tell us which colour wires are connected to which coil terminals?
In fact, can you also list everything else which is connected, to do with the ignition system.
