Name the sensors? (oil filter housing)
(In Topic #143588)
![das_auto in the usergroup ‘Local’ das_auto in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
The picture shows the oil filter housing on my 2.0 6a engine.
Im wondering which connector to stick the wire on that came off the mk1 housing.
My first guess would be the orange/brown one because it looks the same colour as the mk1 one.
If that is so, any idea what the other ones are for, just for reference![:)](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/smile.png)
![](https://farm8.staticflickr.com/7216/7328650246_56e1ff407b_z.jpg)
SDC15427 by gtifanboy, on Flickr
![](https://i249.photobucket.com/albums/gg212/alexw5150/golfy1-1.jpg)
![0b1dhobi in the usergroup ‘Local’ 0b1dhobi in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Black one oil temp located sometimes on the back or side of the head
bottom left i think is oil pressure low
bottom right oil pressure high
I may be wrong but theres a start. :wink:
![Avatar](https://i78.photobucket.com/albums/j95/citigolf_2006/Avatar0.gif)
![Bert in the usergroup ‘Local hero’ Bert in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Bert in the usergroup ‘Paid Member’ Bert in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Forumpic.jpg)
![Early-1800 in the usergroup ‘Paid Member’ Early-1800 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Early-1800 in the usergroup ‘Local hero’ Early-1800 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
If original parts they will have the temp or pressure range stamped on one of the flats of the metal part?
![bah in the usergroup ‘Regular’ bah in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Off topic but i also have Q related to these senders. where i can get oil temp and coolant temp new sensors like these? thanks
![JonP in the usergroup ‘Old timer’ JonP in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
GSF
Eurocar parts
AVS
Eurocar parts
AVS
![](https://img.photobucket.com/albums/v33/jonboy666/Jons%20golf/M25sig.jpg)
yes you have 3 oil pressure sensors there, the white ones are 1.8 bar, black one could be 1.4bar. you cant go by colour if they're aftermarket though so check the markings!
for a mk1 you need a 1.8 bar white and a 0.3 bar brown/blue, the 3rd sensor isnt needed. the mfa oil temp is a small white one in the back of the head, you can move it to the filter housing if that helps you, basically it depending on your wire routing where is best.
