Motorbike engine conversion?
(In Topic #129108)
its a conversion i will be undertaking sometime soon.
any advise welcome.
nees a frame or two but it can be done. i read somewhere that a company does ready made rear engine frames for the mk1 shell to fit a bike engine in the back.
its alot of work tho
booze and boredom, the greatest mix
should have stated……. front mount engine-fwd as i dont really want to loose the seating/boot.
i realise its gonna be a bitch to put the power down, but for now i'll live with it :twisted:
My Build Thread
its why car manufacturers make car engines for cars and bike engines for bikes… if you can get the mk1 down to below the 600kg mark then its worth it cos the acceleration is amazing..
but as above. if you load it with people, you will not only have any low end torque but you will probably burn the wet clutch out as its not built for high weight loads
you would get alot more power out of a 20v turbo or even a 1.8 16v engine for ALOT less money..
i like the idea of the 20v t but its not different anymore. 1 of my mates converted a rascal van to a zzr1100, what a blast that is
(that i know of)
hehe
Re:
Yamaha V-Max Engine?mixerman said
no, bike engines are built for lightweight and low torque figs.
150HP 150TQ
Not sure if it would be easier or better than a more common swap in any way, probably not
Sent from my Pixel 4a using Tapatalk
