Mk4 polo dash into a mk1 golf
(In Topic #92563)
Who else has done it or something similar? I really like this and because of the electrical problems and dash faults that come with the mk1, I would really consider this option and replace the whole lot!
details here:
http://www.vwgolfmk1.o…ms&file=viewtopic&t=24695
g40'd ratter
<div><embed type="application/x-shockwave-flash" wmode="transparent" src="http://w139.photobucket.com/pbwidget.swf?pbwurl=http://w139.photobucket.com/albums/q312/Forgeman/75e604af.pbw" height="120"
Graham
(Boraboy on most other forums)
Cabrio GTI Now in Lhasa Green with running 1.8T AJQ on OEM management.
Coming to bits again for more mods after reading to much on here…
Oh yeah, and a Golf V GT TDi
Volkswagens With Attitude
1988 1.8 carb Golf Clipper
Jamie
just seen this,..i own the golf in the pic
you will need the loom out of the mk4 polo to mate to your existing mk1 loom..
you will prob have problems with the indicator flasher aswell because the mk4 polo clocks has a left/right and the mk1 has one light on the clocks
i also have a G60 engine conversion and didnt have to worry about the loom as its a different one to the dash loom..
you may have to run a wire from the temp sender thou
you will also need a electronic speedo pick up (i used a early mk3 one) as the mk1 is run by a cable driven one
it will help if you have a wiring diagram of the mk4 polo and the mk1 before you start
Help!!!!!
