mk3 golf 2 litre 8 valve into a mk1 1.1
(In Topic #125359)
i have bought a mk3 2l 8v and am going to put in my mk1. i am a bit stuck at the moment, i cant find any thing about it. its all in mk2 golfs.
will i have to use the loom from the mk3 golf and fuse box?
help please!
as for running mk3 management it depends. you can convert the mk3 loom to plug into your existing fusebox, but if its running the old ceramic fusebox i wouldnt recommend it as its quite tricky to do it. if it was me id upgrade to later mk1/cabrio blade fusebox & wiring then convert mk3 loom to work with that.
you could fit the mk3 fusebox but you would have a lot more wire splicing to do to get all the interior loom in, but as long as you know how to use a soldering iron and read wiring diagrams its not too bad. if you look at my fusebox faq on one of the other forums it covers the MK3 fusebox as well as the early/late MK1 & mk2.
fuel wise id fit mk3 polo GT/G40 lift pump, reservoir, main pump and lines. should fit a mk1 pretty easily and you wont need to change the fuel tank. tho obviously if your fillerneck/tank are in poor nick you'll want to replace them as well.
i have got a transponder in the key on the mk3 8 valve. how would i bypass that or adapt it into my mk1??
alternatively take chip out of key, tape it to reader coil then tuck the lot up behind the dash.
thanks
thanks
Really glad i did this to mine, lovely torque
if it\'s got tits or tyres it\'s gonna be trouble
06 Audi A3 (Wifes daily)
