mk3 1.8 into a mk1
(In Topic #141958)
mk3 1.8 into a mk1
so if anyone has made this swap before all i id like to know is will this be an out and in jobby or will i need new mounts?
"If it aint' Rubbin' it aint' Dubbin!
is the mk1 a gti?
and the mk1 is a formal c 1.0
i would imagine you will need a 5 speed gear linkage because the small engine gear box wont fit the new engine if i remember right
and deffo have to move the engine mount on the cam side further up the chassis leg, which isnt to bad with the right tools
i think youll need engine mounts off a big block mk1 (1500cc or higher) small block 1s wont fit and i think the mk3 1s are completely different!
its just the mounts im going to have issues with.
so if a source an engine mount from a mk 1 1.5 upwards will i need a gear box mount from the same spec?
the gear linkage is mk1 specific im pretty sure the mk3 one wont fit im afraid
dont suppose you have any mounts or linkages knocking around.
good luck deffo doable!
ive only got a 4 day window as i run the car and my work wont let me keep a disabled car the workshop :cry:
Its the same old saying though,if you want a 1.8 go out and buy one as your insurance will end up being higher than getting a standard GTI anyway. And not declairing your mods only makes you uninsured !
Loads more stuff requires changing over than just the engine, because you're going from small block to big block. And then there's the fuelling for fuel injection….
Not always :mrgreen:
thats only the things i can think of off the top of my head
