mk2 hubs
(In Topic #73739)
mk2 hubs
does anybody know if its possible to fit mk2 16v front hubs to a gti cabriolet if so what work is involved?
I tried to fit Mk 2 G60 hubs to my cab but found that where the strut mounts to the hub sits in alot further, to correct that I got ajustable top mounts but these were solid so making the ride terrable. You also need mk2 struts for the bolt holes to alighn.
The steering arm also sits alot lower which is ok if you lower the car to suit.
There is some info on vwvortex about this setup on a couple of race cars.
I have now returned to a mk1 setup and have adaptors to run G60 brakes.
Why do you want to fit mk2 hubs?? the only advantage is you get a bigger bearing everything else can be sorted other ways.
Graham
(Boraboy on most other forums)
Cabrio GTI Now in Lhasa Green with running 1.8T AJQ on OEM management.
Coming to bits again for more mods after reading to much on here…
Oh yeah, and a Golf V GT TDi
Going the spacer/G60 route myself , is it any good ?.
Racing is life . Anything before or after is just waiting - Steve McQueen
