mk2 golf engine swap?
(In Topic #89825)
![projectgolf in the usergroup ‘Old timer’ projectgolf in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
i dont fancy injection costs and basically all the work behind it, and limited time scale etc.
Ive been offered a 1.8 carb out of a mk2, pretty sure (99%) its a driver, id like to run this in my mk1, any advice AT all would be good, as to how hard/easy a swap it will be i.e. any major wiring changes?
i know i need to change the engine mount position, is it the same engine as a mk1 cabby as these are basically a mk2 anyway alot of them i.e. early to mid 90s, as its a 1.8 carb im hoping they are the same in many ways
If they are the same engine then ill run a cabby loom to hook it all up, basically any advice would be appreciated, if its the same as a cab, then thats what i want to hear
thanks very much
Josh
![BiG_J in the usergroup ‘Local’ BiG_J in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Correct me if im wrong.
![6UiLE in the usergroup ‘Local’ 6UiLE in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![happyboy in the usergroup ‘Local’ happyboy in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![mclannahan in the usergroup ‘Local’ mclannahan in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
1990 MX5 Mazda
2003 VW Passat 130 Sport
Sylva Fury 'blade powered…
Josh
