mk2 golf engine swap?
(In Topic #89825)
Ok, so after my car decided to set itself on fire, i want to rebuild it, wiht a bigger engine.
i dont fancy injection costs and basically all the work behind it, and limited time scale etc.
Ive been offered a 1.8 carb out of a mk2, pretty sure (99%) its a driver, id like to run this in my mk1, any advice AT all would be good, as to how hard/easy a swap it will be i.e. any major wiring changes?
i know i need to change the engine mount position, is it the same engine as a mk1 cabby as these are basically a mk2 anyway alot of them i.e. early to mid 90s, as its a 1.8 carb im hoping they are the same in many ways
If they are the same engine then ill run a cabby loom to hook it all up, basically any advice would be appreciated, if its the same as a cab, then thats what i want to hear
thanks very much
Josh
thanks very much
Josh
Arn't Mk2 drivers 1.6 carb engines? Im pretty sure they are.
Correct me if im wrong.
You might be right but think they did a 1.6 and a 1.8 mate
i had a mk 2 driver and it was sure enought a 1.6 well 1575 but close enough
1.6 the early ones, 1.8 the later ones (about 1990 onwards at a guess?)
1990 MX5 Mazda
2003 VW Passat 130 Sport
Sylva Fury 'blade powered…
ok cool, anyone out there had any luck with this conversion, or know anything about it? hopefully picking up the car this week
Josh
Josh
