mk2 golf coilovers on a mk1
(In Topic #110187)
I TRYED BRIEFLEY BUT THE HUB IS THINNER ON THE MK1 COMPARED TO THE MK2
(WHERE THE SUSPENTION BOLTS IN AT THE BOTTOM WITH 2 BOLTS)
ON THE MK1 ORIGANAL SUSPENTION THERE ARE PLATES WELDED ON THE STRUTE TO MAKE IT FIT TIGHT,
CAN I JUST PACK OUT THE COILOVERS WITH WASHERS TO STOP IT MOVEING LEFT AND RIGHT OR DO I HAVE TO CHANGE THE HUBS OVER,
WILL THEY FIT???
ALSO IS THIS THE SAME ON THE BACK?????
CHEERS ALL
DuBskiZ
the only diff on the front is there are 2 plates welded where the 2bolts go thro at the bottom,2 make it thiner where it bolts at the bottom if you took the plates out the front suspention would fit the mk2 but i want it the other way round mabe some knows where to buy the plates??
havnt looked at the back yet.
sozz about the caps
DuBskiZ
