mk2 16v into a mk1
(In Topic #74785)
mk2 16v into a mk1
I'd imagine the hardest bit would be getting the electrics sorted out especially if it's for a car that wasn't previously injection.
Alot of work but the end result will be great! Wish I could be more help.
I'm sure someone has done a conversion like this on the PVW forums but unfortunately they're dead!
Owner of a Golf Driver 1.6 G Reg running
twin choke weber carb 32/34. More to come!
if your mk1 has a 1.3 or smaller engine you will need to remove left hand engine mount and reweld further along the chassis leg there are a couple of indents where it sits i think it also needs turning 90degrees.you may need the gti front and side bracket ,if your golf is 1500cc it will bolt straight in,just swop mk1 mounts to 16v engine
To use 16v gearbox you will need a pair of 86 on scirocco or golf cabby driveshafts these have 100mm inner cv joints
fueling would have to be a pair of carbs,if you want to run kjet you would need gti fueltank fuellines pump accumulator basicly a donar gti
for the ignition you would need a dizzy from a early seat ibiza i cant rememember what year and model
Also need a conversion exhaust manifold ashley or supersprint
cheers mark
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
My conversions actually going to be on a mk1 jetta but as such the process is the same as on a mk1 golf.
In the above post it talks about carbs/injection? Im going to run carbs but i thought i needed gti fueltank etc, is it the case that i i wont need to use this as im going carbs? Just run a different pump & lines????
Lloyd
Keep your carb tank for carbs but you will need a Facet fuel pump for twin 40's/45's as they will need more fuel but still at a low pressure which the Facet will do.
Here's some more info on it with loads of pictures:
http://www.clubgti.com…forum_posts.asp?TID=84244
I can see that link coming in very handy!! Certainly guna make my life abit easier!
Currently trying to get my head round everything i will need so that i can be properly prepared!
This won't be the last time i bother you with some questions im sure!
