mk1 Power Steering
(In Topic #80662)
mk1 Power Steering
I had bought a power steering kit from tsr about 2 years ago,
i need to replace the steering column universal joint, :cry:
but i cannot seem to get in contact with tsr
Have they gone bust? or
does anyone know what vehicle the rack they use comes off of, so that i can at least source the u.j. that wat. 8)
Guest user
Afraid they are no more, went into recievership about a month ago, no idea what uj they used, worried that its worn out in only two years though 8O any vw part numbers on it?
Guest user
Who knows, tsr told me that it was a vag rack, not that i realy believe them
maybe take it into a motor factors and see if they can match it up, some of these places often the ones run by the more experienced will be realy helpful
Why do you need to replace the UJ, which part is a problem.
TSR used the top of the Mk1 UJ and welded a different lower part, If the lower part of yours is OK then maybe you could get it cut off, drilled and welded to another Mk1 upper part.
Graham
(Boraboy on most other forums)
Cabrio GTI Now in Lhasa Green with running 1.8T AJQ on OEM management.
Coming to bits again for more mods after reading to much on here…
Oh yeah, and a Golf V GT TDi
chudd said
Am told it may be Nissan?
god help us all…………
My PAS uses a Nissan Bluebird rack...
You should drink more water.
1664 is 95% water.
Drink more beer?
1664 is 95% water.
Drink more beer?
More racks, we need more racks
well basically, i had modified the the steering column with and uprated to a mk4 item, because i'm running a 1.8T lump, due to the immobiliser i was going to install the complete loom, clocks incoporating the immobiliser. But since then i've had the ecu de-imobilised, therefore i don't need to run the loom or the clocks or the column. But i do need to install a Corrado column. This is why i need the uj, because i one-way fabricated it to fit, Why do some of you feel its nissan item?
Does it look similar in mounting points to mk1 unit?
storm81 said
Afraid they are no more, went into recievership about a month ago, no idea what uj they used, worried that its worn out in only two years though 8O any vw part numbers on it?![]()
Not surprised, they charged sky high prices, and apparently (someone on this forum has mentioned it) their quality of workmanship didn't meet customer's expectations.
Still, they will be missed as they were a source for some tuning items, eg 16V Mk1 manifolds.
Is this the rack you got ?
There was alot of talk about this on the caddy forum.
Graham
Guest user
You dont actualy need to run the corrado pedal box and column, you can use your original and either use mechanical clutch (you can buy the gearbox mech off the shelf ?40 from vw) or you can mount the clutch master cylinder onto your existing pedalbox with some simple work
yes thats the rack. Any ideas what if off of???
No sorry, have tried to search for the part number on the net but not found anything
Graham
No need for any overpriced TSR tat, Storm Developments do a better manifold for less money, i have one and its superb.
was going to say,
Theres still Ashleys, Storms (same but S/S), Supersprint…
mk1 power steering
The UJ in concern is the Nissan U11 UJ.
mk1 power steering
