mk1 gti clocks interchangeability
(In Topic #78031)
Hi all.
oil light andf buzzer going off for no reason.
tried the sender stuff but informed the clocks are prone to having mood swings.
can anyone tell me how interchangeable the clocks are for the mk1 golf gti
mine has the mfa function I should also mention.
seen a few scirroco gti clocks advertised but not sure if they would be a direct fit or not.
likewise for the 16v mk2 golf. would love to get one of these as my mk1 is 16v powered.
happy to shift and move wires around at the back clock plugs but no dash cuts.
anyone been here before and got suggestios
Paul
ps
ever88
.fsnet.co.uk
Paul
ps
The Gti clocks for MK1 Golf with MFA have a 14-pin connector. I don't know if non-MFA clocks have the same connector but with less wires or a smaller connector??
This may be what dictates if you can swap.
mk2 clocks wont be a direct swap as I'm pretty sure they all have two connectors.
if you had the time and patience I'm sure you could mess around with looms and stuff and get a set of 16v clocks running properly but it would be fairly involved!
black 5 door mk1 GTD
mk1 scirocco Gli in bits
