Mk1 Golf gearbox oil levels???
(In Topic #132506)
and how do i know how much to fill it with? thanks in advance, Chris
(can be aquired for about a tenner off ebay as part of a set), and a funnel as the plug is parralell to the floor :dontknow:
You undo this plug here as illustrated on my cabby engine which is not in a vehicle.
You can see the gear linkage and diff/drive shaft hole in this pic so should be able to work out the position from that
Im assuming you've drained the transmission oil? Make sure you fill it with TRANSMISSION oil. You will need 1.5 litres for a 4 speed manual box or 3 litres for a 5 speed. If its automatic its different affair altogether.
1991 mk2 golf ryder (deceased)
1983 mk1 golf 1.8 Gti Mars Red (stripped)
1987 mk1 caddy 1.6d Matte Black (deceased)
1990 mk2 golf 1.8 8v Gti Tornado Red (sold)
Now car-less and looking for a long term ride.
The gearbox code includes a date code which you can decipher so you know if yours is one that needs the above.
I was advised, and I have, to use 10/40 part synthetic engine oil. Normal transmission oil will deteriorate over time, particularly on low mileage cars.
Make sure the gearbox is empty, don't use the normal filler plug, pour it in via the speed cable hole, it will go in a lot easier.
Also, I am not sure where the 3 litres comes from for a 5 speed box, I have used 2 litres plus an extra 0.25 litre, total 2.25 litres, to ensure that the 5th gear mechanism gets lubricated.
There is no danger putting this extra 0.25 litres as the gearbox is vented. Black cap on top of gearbox.
