Mk1 Golf Engine Mount Bolts Help
(In Topic #118673)
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
try Under Construction
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
Although they do look pretty
I know some odd stuff happens with aluminum and mild steel start to rot.
I'm using stainless for two reasons, the first being my friends concourse RS turbo is held together with them, and secondly he recomended them ( he is a buyer for industrial grade construction fasteners ), so I think my car will be ok.
It also doesn't see much wet weather, and sure as hell don't go out in the winter months.
If the car is kept dry then you are probably doing the rightl thing and it shouldnt really matter as the corrosion process needs an electrolyte which on a car is usually rainwater, but this can also be dampness in the air.
The closer they are on the galvanic series the lesser the likleyhood and the agresiveness of the corrosion.
I do hope to keep the car for the long term, so maybe I need to be looking elsewhere for fastenings.
Anyone know any other potential suppliers?
Its the route I am going down with nearly all my bolts.
I'd be more worried about the strength of stainless steel bolts on critical components - and I'd include the engine mounts on this list. If you can be assured the strength is up there, then by all means they're okay to use.
Quite costly though, compared to normal stuff, if you're going to be replacing a lot of the stuff on the car.
Search around a bit and try to buy in bulk - many times cheaper than nipping to B&Q for a packet of bolts etc!
paul_c said
I think the corrosion angle is a bit of a non-issue.
I suppose it all comes down to how much you care about your motor, but IMO theres no point encouraging corrosion if you are being so meticulous in its re-assembly.
Any load bearing bolts on the cab have replaced with VAG sourced fittings, such as wishbones and brake calipers.
Most of the stainless hard wear on my car is holding non load bearing bits onto the engine, save for the front engine mount cup.
I have used stainless to replace mild steel as the car is undergoing a long term resto and some bits will be on and off a fair bit. stainless seems to have a greater resistance to rounding + key areas are being greased after assembly.
Didn;t think this would be such a hot topic!!!
8O
Hold on, I'm arguing against myself now
