mk1 g60 drive shaft problem
(In Topic #88000)
Basically the car has a really nasty knock sound and the garage has narrowed it down to the long drive shaft being too long and it pushing up into the gearbox. It has standard mk1 gti driveshafts on. It is the longer driveshaft on the passenger side.
It does drive and has driven, getting worse when I changed from the 16 inch wheels to the 15 inch.
Should it take a different sized drive shaft? Any ideas or help would greatfully be recieved.
Many thanks
Damon
Did they grind down the inside of the CV to fit all the way onto the spline? If they didnt and just put them on as far as they could it could be causing that.
I'm running mk1 gti shafts, with 100mm inners, but had to turn down the internal spline on the CVs to get the inners all the way on to the shafts, to be totally honest the shaft are still too long, it runs fine, no obvious knocking, but does still eat CVs.
if thats the problem, as you said, find some late cabbie / rocco shafts which come with 100mm inner cvs as std, theyre shorter shafts. if you can find some.
just an idea.
Do you know how late on cab models the ones came that were shorter? I'm willing to try anything.
Many thanks Damon
this implies 87+. But it's not ALL late cabbies, I don't know which ones exactly. I have an 89 clipper as well as the tintip, and it doesnt have 100mm inners.
is it rusty???
is it over priced??
YES!!!
i'm on my way over to pick it up
is it over priced??
YES!!!
1983 mars red 1800GTi on ATS cups
G60'd, schrick cam, chipped, 70mm pulley, pace charge cooler, rolling road 182bhp 250Nm of torque, 14.50 quarter mile.
