mk1 brakes, scirrocco callipers and 280mm discs
(In Topic #141951)
im not sure if its something obvious im doing wrong or if this combination of scrap doesnt actually work together?
if anyone has this set up or any pics of it fitted this would be great as it seams like one step forward, 10 back as usual!!
mat
i think someone put the figures up somewhere i'll have a look in a bit. go out and measure yours and worst case i can measure mine and we can compare lengths
Mat
http://www.clubgti.co.uk/forum/showthread.php?t=241335
if yours are narrower than 53mm then by the sounds of it you have 256mm solid disc calipers, no wonder they dont fit!
Mat
easier way is get g60 calipers, or mk3 pre-96 gti/16v/vr6, or high spec passat, corrado, seat ibiza, toledo, cordoba etc. basically any vw or seat with 280mm brakes
So rant over what car has the correct callipers on I need, I'm just gonna go and buy some, ideally that will work with the brackets I have (they have the same bolt spacing as a standard mk1 just further out)
Need to no exactly as I'm fairly sure guy in motor factors won't have a clue
288 on the left, 280 on the right:
