mk1 20vt AGU wiring diagram
(In Topic #150781)
hi guys i'm in process of installing a AGU engine on a mk1 (ex 1.1)
is there any DIY diagram to make it work?i have the full donor car but i'll decode the ecu so i don't need to use clocks and keys.
what i need to know is,what is the basic diagram to make the engine work.
if it can help the agu is cable operated throttle and i won't use:
PAS
A/C
electronic speedo
thank you very much!
PAS
A/C
electronic speedo
that's for a mk2 with CE2,it the same for a mk1 with CE1?
thanks
thanks
Might be worth sending a PM on here to rubjonny to see if he has one as well mate.
its a starting point and as close as you will get for info on making up a loom.
thank you guys any other advice will be appreciated
read the whole thread there are lots of tips, i cover CE1 wiring a couple pages in
agu is similar to aum/auq, just be aware on the really early ones the pinouts on the coloured plugs differ slightly. see my sig i have agu early and late diagrams
