mk1 20vt 02j swop general...........
(In Topic #139292)
1. i got the gear cables gear stick/tower the lot that suits the box, obviously with fabrication, will the cables reach the box ok - too short or long . it looks ok to me. i was gunna run them under neath and widen the hole etc.
2. i got the full hydraulics from a Mk4 TDI golf, master cylinder complete in the clutch pedal box, the line from master to slave with slave still connected. With reinforcement of the wafer thin fire wall the pedal box should just bolt on shouldnt it with fabrication. The lines with a little gentle bending should fit too . Any one else done this route of simplicity. Ive read all these threads and it just sounds like they make hard work of it.
The TDI hydraulics will work fine wont they ?? ive done hundreds of clutches/flywheels etc on these they all look the same !! i see no reason why it would not.
Its annoying as i want to do it now but realistically cant do it till the new year !!! unless i do it over the new years holiday but what a rubbish/anti social start to the year !!
I want to throw my 020 box in the sea…………..
Where you planning on putting the master cylinder? you going to put it on the driverside then?
06 Audi A3 (Wifes daily)
I also used a honda civic clutch fluid reservoir, i fixed it in the gutter area near the wiper motor as high as possible. The system bled out easy too although as there was no fluid in the master i had to suck it through the slave bleed nipple to get it started.
Really happy with the gear cable change to silky smooth operation , just got to put my new dash in now and my mega project is all done !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
