MK1 20 Valve Turbo Wiring
(In Topic #150555)
You send him your loom from the 20vt engine and he will make it pretty much plug and play for £130!
Thought I would spread the word
Log into Facebook
Will update when it arrives. (today i hope!!)
Shame rubjonny is so rammed out with work. He is the man to do your looms
I sent the loom to him on tuesday and he sent it yesterday!!
Not bad ey!
Everything is labeled and only 4 wires to connect up!!
Im really happy with it. I just hope it all works!!!
Good luck
Birmingham
c11rgd said
You should put up some more pics, and close ups, so others can see how its done, might be helpful for people who wanted to do a DIY jobby!
Its all wrapped up in tape so you cant really see.
I dont think its fair to put a guide online as it would lose Vagtronics business.
There is lots of info online if you want to do it yourself eg http://www.clubgti.com/showthread.php?205887-OEM-management-wiring-1-8T-gt-Mk2-harness-install-FAQ
i was just suggesting it would be good to see what they have done, and what info they provided to you in terms of where to wire your AGU loom into the mk1 etc.
Also i noted they have used inline fuses,i havent used fuses in my loom as the mk1 never needed i, i guess its an added safety precaution, did they use any resistors? as they are really only required if your not going to edit the codes on the ecu.
just would be good to know what your getting!?
Birmingham
with my looms i integrate the loom to make it as close to how VW would have done it factory, plus i also strip the unneeded wires from both looms and join them together
thats a megasquirt loom by jubjonny plug and play everything working out of the box.
if i rember correct
1 live
2 earth
white clip in bk of fuse box
5 clips on engine bobs your uncle
brummmmm brummmm
Last edit: by peterg60
