MK1 20 Valve Turbo Wiring
(In Topic #150555)
This chap is doing my wiring for my mk1
You send him your loom from the 20vt engine and he will make it pretty much plug and play for £130!
Thought I would spread the word
Log into Facebook
Log into Facebook
I've seen him advertised on eBay mate as well. I think he's well known on other VW forums. Hope he does a good job on it mate
Ok that sounds promising. Yeah im sure it will be ok.
Will update when it arrives. (today i hope!!)
How long did it take to do then mate?
Shame rubjonny is so rammed out with work. He is the man to do your looms
Yeah I wanted him to do it, but he is too busy!!
I sent the loom to him on tuesday and he sent it yesterday!!
Not bad ey!
Not bad ey!
Sounds like a good service mate. I hope it's good quality and labelled properly. Stick some pics up when it arrives
Everything is labeled and only 4 wires to connect up!!
Im really happy with it. I just hope it all works!!!
Smashing work. Think even I could wire that up if it is just 4 wires
Good luck
Good luck
That's a good link, thanks. Let us know how it turns out
You should put up some more pics, and close ups, so others can see how its done, might be helpful for people who wanted to do a DIY jobby!
Birmingham
Its all wrapped up in tape so you cant really see.
I dont think its fair to put a guide online as it would lose Vagtronics business.
There is lots of info online if you want to do it yourself eg http://www.clubgti.com/showthread.php?205887-OEM-management-wiring-1-8T-gt-Mk2-harness-install-FAQ
Fair enough mate, but the whole purpose of forums like this is to gain free knocwledge, companies like Vagtronics exploit the market, Ive built my loom and its not that hard, people like RubJohny charge less do a fantastic job and wont turn anyone down in providing free technical advice.
i was just suggesting it would be good to see what they have done, and what info they provided to you in terms of where to wire your AGU loom into the mk1 etc.
Also i noted they have used inline fuses,i havent used fuses in my loom as the mk1 never needed i, i guess its an added safety precaution, did they use any resistors? as they are really only required if your not going to edit the codes on the ecu.
just would be good to know what your getting!?
Birmingham
all he has done is wired up an external relay to power everything, and left you with live, earth and ign live feed to power everything up. in effect totally bypassing the mk1 fusebox. works just as well really and also is a good plan if you have the crappy ceramic fusebox.
with my looms i integrate the loom to make it as close to how VW would have done it factory, plus i also strip the unneeded wires from both looms and join them together
I'm guessing that's why you're rammed out with orders till next summer mate
yeah my way takes much longer
Quality takes time.....
daw you flatterer you
thats a megasquirt loom by jubjonny plug and play everything working out of the box.
if i rember correct
1 live
2 earth
white clip in bk of fuse box
5 clips on engine bobs your uncle
brummmmm brummmm
Last edit: by peterg60
i wish! dont really get thru them fast enough
