mk1 2.0 16v conversion quick question!
(In Topic #73206)
And any more helpful advice on conversion??
TA!
Our member G60RGE has recently done a 16V conversion so I hope he may be able to answer your questions (including your other post about 5th gear ratio.)
Check his post http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=1320&highlight= to see if this helps.
I'm sure he'd give you any advice you need.
Re: mk1 2.0 16v conversion quick question!
mk116v said
Hi new user first post i have a 82 mk1 originally 1.6 gti soon to be 2.0 16v seem to have most things in order but just wondering will i need bigger fuel pump if so does anybody know which is best suited?
TA!
hello ello!
the standard 8v gti pump is sufficient to run a 16v no problems provided it is running on k-jet injection..
the only thing u need to do is bend your fuel lines over to the opposite side of the engine bay to reach the metering head/fuel distributor which now has to be on the left unless u have been lucky enough to get ur mitts on a scirroco 16v inlet manifold 8O !
anything else u need give us a shout!
good luck mate
Thanks for the replys,i actually changed the engine to a 1.8 16v(kr) about 3 years ago and never drove as i then sent it off to be respayed and between me moving house and the guy being busy we are just getting round it doing it now
I have used an ashley 4-2-1 exhaust and having the head re-worked and 2.0 bottom end re-worked.
Cant wait to get back in it
Oh yea one more question which radiator is best ?Is the 8v one upto the job?
good luck with it, get some pic up when u can!
(As you now know, the fuel pump has a similar flow capacity, and the radiator is also relatively similar - a bit bigger on the Audi, but not enough to cause you trouble when using the 16v engine with a Mk1 radiator.)
Thanks once more for the replys this is a goood site i have posted on other forums and had no replys!,but not the case here !
The 2.0 bottom end is actually an 'ace' audi block so thanks for letting me know'type 17'.
I will get some pics up of my car and the rebuild as soon as i get back from hols in a week 8)
Your car looking really well g60rge!
And another question about the conversion which is best head gasket to use and would it be better to be genuine vw or aftermarket??
PS: Just checked the make of the (good-quality) sump gasket I have in my stock, and it's a make I see a lot - "Topran" - see if they do Head Gaskets too.
