mk1 16v wont start
(In Topic #145174)
mk1 16v wont start
can anyone help me or suggest anything, the car is a mk1 16v running a 2.0 9A engine, Kjet so ive been told
Also tweak the ignition timing whilst trying to start it, rotating slowly forwards and backwards may catch a fire that way. Firing to all 4?
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
i have my fuel pump buzzing and so is my isv, fuel going into metering head but just not reaching the injectors (or very little reaching anyways)
how do you adjust your metering head flap so that it doesnt stick, mine squeeks when lifting, im guessing this isnt ideal?
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
chipster2407 said
I had the same problem brad but luckily cuz I took it to crazy quiffs they found out it was the metering head straight away, changed it for another n it work fine![]()
i had a spare metering head lyring around in my garage, last night i put it on as a last resort and it worked 8)
its running rough but its so good to hear the engine noise for the first time.
when giving it a bit of throttle the engine splutters and doesnt like it, is this the ignition timing or something else?
also if anyones reading this and knows about 16v's, i know there are issues with the manifold touching the steering rack boot, well mines doing this and pretty bad, smoking and burning the boot, ive got the majority of the exhaust heatwrapped and a layer of heatwrap around the boot but its still a bit scary how hot the manifold is getting and being so close to the boot
any help?
Firing on all 4 cylinders? Tweek timing slightly when ribbon see if it gets any better.
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
Have u checked all the vacuum pipes? This seems so wierd cuz all the problems ur havin is what I had lol, mine wasnt running very well not long ago, after a quick look ova it turned out to be a vacuum pipe had come off, also have u put new plugs and leads on it?
Also with the steering rack boot I had this problem and I asked on the gti forum n some basically showed me what they did n they basically got a can of something( I used a big can of red bull) cut the top and bottom off it
And the cut it down the middle, then put aluminium tape over it then wrapped it round the boot and put slits in the can and then put the ties u use on the heat wrap through the slits and that keeps it in place, I did this and havnt had a problem since, this is if you havnt got the patients to do what cabby rad have done
Hope that helps
il double check the vacuum pipes tommorow but as far as i know they are all in place, i do need some T pieces for the pipes to splitt he ones for the over run cutt off valve etc as ive just ran them from the other outlet on the valve and ran one directly to the ecu, so maybe thats why its not running right too.
i have put new spark plugs on but just used the old leads, as for the heatshield that sounds like a good idea, il give that one a try and see if that improves it at all. thanks, oh do you have a link to the thread you followed for the 'can shield'?
I'd also check for air leaks too sounding of it.
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=115672
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
Metering Head
