mk1 1.3gt conversion - Help
(In Topic #129525)
Well….i recieved my first little project yesterday, a 1983 Mk1 1.1 C.
Now when it comes to cars im not a mechanical genius as I have always been in to motorbikes, so what I want to know is there anyone that could have a look and tell me exactly what is needed to complete the conversion etc, even better someone that can complete the conversion for me?
Any help would be appreciated or if someone can point me in the right direction or know of a garage or someone that might be able to help me with this.
Thanks!
are you going to run the multi point injection?
if so have you got the fuel pump?
how much of the wiring has been done?
might be easier to post pictures
there is quite a few threads on here that will help you with exhaust and a bit of wiring
i had to use wiring diagrams also
Ive got the fuel pump yes. Yes i will be checking out all available threads for help on this.
Not to sure how much wiring has been done but by judging I would prob say half. Pics will follow…
i would say you should run the mpi tho
i had to file down the drivers side engine mount to fit the alternator
here are some diagrams to help you:
if your going to run the polo gt exhaust manifold and down pipe you will have to cut the catalyst of as it fouls on the mk1 body.
this will have to be mated with a mk1 golf gti exhaust system
at the moment im using the mk1 golf manifold+exhaust system
are you using the whole polo loom up to the fusebox or is the polo loom spliced into the mk1 loom?
as you can see its not completely finished but I fired it up a couple days ago, still need to make a bracket for the air filter and find a home for the ecu and coil + tidy the wiring up.
i did away with the expansion tank and just blocked of the hoses running to and from it
im using the original 4 speed for now, but will eventually swap for the polo 5 speed box.
radiator wise, im still using the mk1 rad, but im going to use the polo fan cowling hopefully with the mk1 golf fan motor, this is so i dont have to splice the fan plug from the polo in.
i haven't driven it yet because it has no brakes but seems to run ok, think i need to get a new exhaust gasket because its leaking a little
Do you think it will be neccessary taking the motor out again, opening it up and giving it a once over or get it hooked up first and see. I think the motor was a runner before the conversion but it has been standing for a while.
I read somewhere else that I can use the mk2 polo radiator with the mk1 fan, cowl and switch so the wiring is standard….
Where about are you based mate?
just looks like a better fit
im up in the lakedistrict, bit far to give you a hand lol
The previous owner told me i will need driveshafts as well so need to get that to. Going to be fun few months!
