Measuring drive shaft lenght?
(In Topic #146307)
How would I go about measuring to establish what lenght driveshaft i need as i need a passenger side shaft fory mk1 vr6 conversion and trying to get a shaft somewhere?! :dontknow:
Thanks!
Short shaft: 445.5mm
Long shaft: 658mm
Scirocco / Golf Cabrio with 100mm inner CVs
Short shaft: 433mm
Long shaft: 650mm
Golf 2 / Mk2 Ibiza / Mk3 Ibiza
Short shaft: 432mm (confirmed twice)
Long shaft: 681 666mm
Golf 2 non-GTI
Short shaft: 443mm
Long shaft: 677.2mm
Golf 2 GTI
Short shaft: 447mm * Haynes are wrong*
Long shaft: 681.2mm * Haynes are wrong*
Golf 2 Rallye (4 stud)
Front short shaft: ??mm
Front long shaft: ??mm
Rear shaft (left): ??mm
Rear shaft (right): ??mm
Corrado
16V / G60 (4 stud)
Short shaft: 432mm
Long shaft: 666mm
VR6 (5 stud)
Short shaft: 448mm
Long shaft: 666 682mm
Golf 3
non-GTI (4 stud)
Short shaft: 443mm
Long shaft: 677.2mm
GTI (5 stud)
Short shaft: 447mm
Long shaft: 682mm
Passat
4-stud (~88 - 96)
Short shaft: ??mm
Long shaft: ??mm
VR6, 5-stud (early to mid-90s)
Short shaft: 456mm
Long shaft: 688mm
Golf Mk4
2 wheel drive (5-stud)
Short shaft: ??mm
Long shaft: ??mm
4 wheel drive (5-stud)
Lupo GTI
Short shaft: 430.5mm
Long shaft: 656mm
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
Are these with or without the CV's?
Might give the Golf 2 or Lupo shaft a try as they seem to be shorter…
Club Gti Driveshaft Lengths
I was thinking of grinding down the ridge in the second pic but not sure that will make to much of a difference?…
Here is the shaft on its own, measuring at 432mm…
