lowering problem
(In Topic #75655)
lowering problem
ok i decided its time to get some new shoxs and springs for my car
FK SUPER SPORT SUSPENSION KIT adjustable rears 40mm all round ok
i fitted them today no problem built them up blahh blahh blahh ..
and it turns out my car is a lot higher than when i had 35mm on the rear and 40mm on the front
its like im driving a moster 4x4
douse any body know wats going on
:dontknow:
:dontknow:
How long has the old suspension been on, can only think its natural compression with time. I've also noticed allot of the suspension decriptions say 35-40mm so that could also be a factor.
Did you also put in new top mounts etc the old ones will have allso been compressed a bit.
Rob
Rob
Audi A4 1.9TDI - Gone
its only new springs and shoxs every thing else is off my old set
it may well be in time needed but ive droped the back 50mm and front 40mm and its like its getting higher i really hope it dropes it looks horrible
its only bin on my car for a few hours
but the old 1ns were on for a bout a year
Well I'm now lost, I think if it was me I would find out the original ride height figure and then check what I have now. It will defiantly give you a starting point (I think they call it a datum point in scientific circles).
You should then be able to see if the new ones are not giving you the 40mm or the old ones were more like 60mm!!!
Someone on here must have the height info?
I seem to remember that measuring from the very centre of the wheel to the wheel arch lip, it should be 320mm as standard (on a GTI). Not 100% sure on this but thats what I recall :?
MK1 GTI Campaign
MK2 GTI 8v
Imitation Magic Tree - 'Black Ice' smell
Plenty of rust
Embarrasing fuel problem
Porous cooling system!
MK2 GTI 8v
Plenty of rust
Just for reference my colf cab is 340mm on the front and 320mm on the rear, It has standard suspension and i would say the front top bushes have been changed. It does sit a little low on the rear IMO than it should.
A starting point and would backup shortsuffs quote.
thank you all
I'm no mechanic so i had a garage lower mine for me, when i picked it up it was higher than before.
He the fobbed me off saying it wil drop and i didn't believe but said i would give it a go for a few days! Ok I was wrong! It dropped a hell of a lot over the first few days!
i have also found that on the rear struts there was a silver thing that the suspension sits on on the botem of the spring when its on ..if you get wat im on about that was up sid down wich raised the car an extra 5cm wich wont help... lol
