Lowering kit gone wrong...
(In Topic #79375)
Just after some advice really. I fitted my new Koni TA kit this weekend, and although everything seemed to look right off the car, once I'd got it fitted, the car sat at an odd angle, with one front wheel lower than the other. Also, when I was checking the firmness of the new suspension, I could feel the suspension bottoming out on the side which was lower.
I think this must be due to a weak or wrong spring as opposed to the damper - am I correct? The dampers fitted in ok, and were both the same size, but I didn't check the springs were the same (although they fitted with what felt like the same amount of tension applied).
I'm very confused as to why this should be, as I built the two front struts up side by side, and I'm sure they have the same parts on each, but before I phone up for a replacement I want to check that I'm not being an idiot!
I've double checked the measurements from the centre of the front wheels to the underside of the arches - one side is 310mm, and the other is 290mm.
Could anyone shed any light on my problem?
Rich
P.S. The rear suspension is fine and looks really nice!
As said, check the springs are sitting correctly. Otherwise, you may have been given a wrong spring - Too short or maybe even the wrong spring rate.
You say you can "Bottom it out" when you press the wing down - Try cranking the damping adjuster right up to max and try again. If you can still move it, the damper is knackered, though I don't think this would cause it to sit funny.
I don't think you should be able to do this on the softest setting to be honest?!? :dontknow:
My Build Thread
The springs are definitely both sat correctly in the cups, so I don't think that's the problem. Also, when we cranked the dampers up to the max, they both became so stiff that we could hardly move the car at all! Don't think I'll need to use that setting…
I'm beginning to think that the springs were either the wrong length or rate, like you say Al. I'm going to phone awesome GTI today to see what they say…
Thanks again
Rich
mcscrew said
we cranked the dampers up to the max, they both became so stiff that we could hardly move the car at all! Don't think I'll need to use that setting…![]()
Take it for a spin on a nice smooth twisty road and come back with your new opinion! :wink:
My Build Thread
Peter.
1980 1600 GTI, daily driver.
JOEL GTI
1979 mk1 c 1.1L 33k sold
1983 mk1 GX 1.5L sold
1983 mk1 gti 1.6 cab sold
1984 mk2 polo 1.0 rat sold
1982 mk1 gti 1.8 sold
1984 mk2 GTI 16V vw motorsport project 16V very rare striped dead!
1985 mk2 GTI 8V runing 140BHP (track car) striping! Dead
1986 mk2 GL 1.8Ldead
1987 mk2 GTI 16V SOLD
Lots of mk3 gti's vr6's and a tdi all sold
1992 mk2 GTI 8V runout edition sold then bought then sold the bought back and striped!
1990 mk2 GTI 8V in tornado red new car
It's supposed to be 40mm - I phoned awesome GTI who I bought the kit from, and they confirmed that I have the correct part numbers on the springs though (and both springs match).
I'm stripping the front suspension on Saturday to carry out some basic tests on the shocks and springs, and depending on what I find awesome will replace the faulty components as early as possible next week.
Awesome have been really helpful and have already reserved me a replacement set of springs. I can't recommend them enough actually - if anyone's thinking of buying from them I can assure you they are brilliant to deal with.
I'll keep ya'll posted as to how I get on…
Rich
I stripped the springs over the weekend, and they are definitely different strengths, despite having the same part number written on them.
I'll hopefully have a new pair delivered to work on Tuesday, so I'll fit them this week and give them a while to settle.
All part of the "joys of motoring" as people on here have said before!!!
Rich
My Build Thread
AL_Mk1 said
Glad you found the cause, though that is bad of awesome to have sent out a kit with mis-matched spring lengths!
He said strengths al
Just in case that still doesnt work this is from a post on Club gti
tim said
Jobs so far:
take off strip down rear n/s suspension - some one put the spring mount on upside down so that corner sat 2" higher than the rest of the car! lol
Al - I knew what you meant
Also, I should say that awesome have been very helpful in sorting this out for me, and it was Koni's fault for supplying the mismatched springs to awesome.
However, Koni themselves have been helpful so far (touch wood) and my replacements are due to arrive today. They'd better as I'm fitting them tomorrow afternoon!
Rich
My Build Thread
Only a year ago I fitted a set of GSF rear springs on my cabby, these are being replaced with genuine VAG items at four times the cost. Within a couple of months, the rear of the cabby began to sag* so badly that it began to bottom on speed bumps at any speed.
Last week, I fitted some really lovely 15" BBS RA's and those GSF springs must go.
Tim Hale
*or was it all those pies?
