Lets see your 02S conversions
(In Topic #139436)
Many been carried out? Would like to see how youve gone about it and what starter flyweel and clutch you used?
were not as lucky as you to find 1 !!
cnt you use a 02j flywheel and starter as its the same casing ?
foxy
foxy
02R? I cant use the cable conversion thingy on mine a there is not enough room so have to go down hydraulic route, which to be fair I dont mind, was just been lazy!!!
02R polo 130 pd tdi 5 speed cable change box
engine and box going into a mk1 8)
Bert
Its all about 6 gears
Careful when ordering a slip diff for it tho, my mates just done £500 in cold blood from peloquin in states only to find out theres 2 different types, got to send it back and buy another!! whoops!
Website Manager
6 speed 02S is not far of a 02J and not much heavier either. No ltd slip diff either
my 02s conversion with peloquin diff, there is over 20,000 miles on it now
Fitting A Peloquin Diff To An O2j Box | Volkswagen Automobiles Forum
Inaris silver series 1. APX 1.8T REVO software, hybrid O2J/O2S 6 speed, peloquin diff, cabrio drives, toyota pas, 7.5x16 5X100 compomotive mo flatspokes, G60 ABS, 305 brembos octy vrs rears, coilovers and arb's by H&R
What selector mech did you use with your box syncro, am I assuming mk4 flywheel & clutch? Also what pedal box did you fit to your mk1 as im assuming you went hydro as I cant get the seat cable thingy to convert it to fit.
I used a mk4 golf gti 5 speed gear shifter, i used a corrado g60 flywheel and a helix autosport vr6 clutch. i used a clutch master cylinder from rally design and made a bracket to attatch it to the steering column inside the car
thought you could only use a 6 speed gear shifter on a 6 speed box? That hydro clutch looks complicated, any reason you went that way instead of fitting a pedal box from say a passat b4 or summin?
edited:is that a dbw tp I see?
Thats the norm for the mk1,other pedalboxes would be even more work to fit
ps what size master cylinder did you use, and wheres your fluid line feed going into?
i cant remember the size but there were 3 sizes available and i picked the mid size one, the resevoir is mounted by the wiper motor
