KR in my 1.5 GL
(In Topic #119984)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/rm%27s%20mk1small.jpg)
![isaact4 in the usergroup ‘Regular’ isaact4 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
KR in my 1.5 GL
will my drive shafts fit the gearbox from the KR?
my GL was 4 speed so what would linkage would be best to use on the new box, as its 5 speed ?
Last but not least….do I need to change my rear engine mount because of the different box?
would really appreciate ya input on this, will be posting up some of the build pics soon, many thanks! Isaac
as for mounts, they're all the same except for the top mount bracket on the box, need a 5 speed one, plus 5 speed gear linkages obv.
AFAIK basically it boils down to modifying it till it will allow you to move the stick to where 5th is, I'm sure you'll be able to figure it out once you're under the car.
