If you were going to put a V8 into a Mk1 Golf.....
(In Topic #106421)
a) Track down a Northstar or Volvo XC90 to put it in transversely and driving the front wheels? (For example: http://www.forumeter.c…ideo/11416/Coupe-DeGolf-1)
or
b) Put it in longitudinal, RWD (Example: http://uk.youtube.com/…sy6qbPc4c&feature=related).
Obviously, both would be a lot of work and the engine bay would be a little cramped. Both have their specific advantages and disadvantages:
Transverse
- Retain much of the original bulkhead, so interior space isn't compromised.
- Probably less fabrication or 'rebuilding' work, since although the front half of the car would need major work, the rear can stay similar (axle, fuel tank, etc)
Longitudinal
- Much wider choice of engines and transmissions, so could go for higher power, etc.
- Better weight distribution - engine can be mounted further back
Any thoughts?
1989 caddy
1981 gti
1993 cabby
1981 gti
1993 cabby
nice thought though …… mmmn
Cero said
Don't think the Mk1 would be wide enough to take a transverse V8. I think the issue would be the box, so longitudinal for me. That way you could cut into the bulkhead and re-fab a new wall and tunnel. Why a Northstar or XC90? there are so many decent much better producing power V8's to consider.
Those 2 V8s are transverse FWD ones. Unless you know of any more?
axle off and it will fit altogether
with the engine in the frt of this, you get the full set up for the rear, stick
a R32 in with it instead of the 8v. and have the bell housing re drilled to suit
perhaps ill look into the this as i quite like the sound of a turbo so imagine 2 of the buggers whistleing away yum yum
Re: If you were going to put a V8 into a Mk1 Golf.....
paul_c said
…..Any thoughts?
As a matter of fact, yes. This is only if "I" were going to attempt to do this, not advice.
Find a car as close to the same car, wheel base and size, that has a complete frame under it. Remove its body, cut the frame to fit under the Golf. If it did not have a V8 then weld in mounts for one. Cut away whatever needs to be cut for the Golf to drop onto the frame. This will take care of steering and the drive axle both. I've seen some drag Bugs done this way so there has to be some framed cars close enough in size to make it work. Inside might need some modifications, transmission tunnel and so forth, but we are talking custom here.
