How would I go about converting from brake drums to discs
(In Topic #136097)
Also, is it possible to paint the callipers? Thanks
'83 Mk1 Driver - Mars Red
http://www.clubgti.com…m/showthread.php?t=177988
or you can go with mk2 carriers and either mk2, mk3, or mk4 golf calipers
i would go for mk4
it is also neccesary to get some sort of brake compensator valve or the back wheels will just lock up
Theres numerous guides on here about changing to rear discs, cant remember which mk of golf hubs you need to use. Just do a search on here.
Are you upgrading engine performance? As the rear breaks on a golf do very little anyway, as its such a light car, I've heard problems where people have had a lot of rear lock ups after carrying out the conversion. As long as the rear drums are in good order and the hand brake is adjusted up they will be more than adaquate for your needs I would suspect.
The money you spend on a rear disc conversion would be better spent on a bigger disc conversion on the front and the larger master cylinder mod in my opinion.
06 Audi A3 (Wifes daily)
