HELP
(In Topic #73748)
HELP
Cheers Sam
NOT REALLY INTO HIGHLY MODDED MK1S ON THIS SITE,
SMALL MODS ARE COOL THO, HAVE YOU ANY STYLE IN MIND,
GIVE SOME INFO ON YOUR MK1,
COLOUR ETC…. :dontknow:
Im going for a euro style golF low, wide wheels, change you indicators, tail lights head lights(clear lights usually a safe option)
Remove the trim lines (along the side's) door handels, boot lock.
Heres some links happy hunting!
http://www.autostyle.co.za./index1024.htm
http://performancecentre.carpartsdata.com/?404;http://performancecentre.carpartsdata.com/p/Home.asp
http://www.body-kit.co.uk/acatalog/volkswagen_golf_mk1_styling_accessories.html
1.3 Driver - 1.8t in progress
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=56551
Daily driver : e36 325 tdi se / slammed on konis and bbs rco401's
Daily offroader : discovery 1 6" lift monster
Is it possible to convert my mk1 brakes to servo assisted and how would i do it.
How much will it cost and where could i get a lowering kit from, what is the ideal size to lower??
i am not that knowadgeable on brakes :? , however i has seen kits, as for lowering theres certan factors you need to take into acount.
First of all, the lower your car is the more straine is put on ball joints, drive shafts etc. Secondly you need to take in acount driveability lower it too much and it may upset the handeling and most importantly how many sleepin police men are there in your area?
Alot of classic car enthusiast go for the 1 inch drop (40 mm) which gives a much nicer, more agressive stance on the road whilst still being able to pop down the supermarkets each day
http://www.awesome-gti.co.uk/vw%20golfmk1/suspension.html
http://www.camskill.co.uk/products.php?plid=m14b26s1111p3525&tbv=APEX_LOWERING_SPRING_KITS_-_GOLF_MK1_inc_CABRIO_X-LOW_-_&
http://www.awesome-gti.co.uk/vw%20golfmk1/brakes.html
There are quite alot of sleeping policeman in my area so i will defentetly go for 40mm drop, someone on demon vw is selling me a set of apex 60mm springs for 50quid which came of his mk1 he said 'you just use the standard shocks, and remove the springs using a set of springcompressors, you can get from say halfords, and then rebuilding the shock in the correct order, keep everything in the right order', better than paying out 100quid+ on the kits. Does the look of the mk1 look nicer when they have been dropped by 40mm?
Spring compressors will do the trick but i'd try to get them somwhere else than halfords (they're rip-off merchants in my area!)
Heres a example from the owners photos, mikey i think, nice
http://www.vwgolfmk1.org.uk/modules.php?name=coppermine&file=displayimage&album=1&cat=0&pos=50
p.s if u go to all the hassle of paying 50 quid for lowering springs and fit them (which can be a royal pain as some of the nuts dont wanna budge) buy yourself a boge or bilstein kit with gas shocks and shiney bits
paul
