help wanted mk1 engine conversion what to do????????????????
(In Topic #77727)
if its only a 1.1 i have a 1.3 you can put in it, with out swoping anything easy to put in to,
simon
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
Not worth spending time and money on going faster until you have experienced and got used to a 1600 which I am assuming from your post that you haven't.
I am sure it will raise a smile
for outright performance you cant go wrong with a 2L 16v 8)
U want regret it!
I'v used corsa diesel rad that fits under slam panel and fans are scorpio cosworth twin jobie which is well slim
Need extra room as i will be going throttle bodies route as soon as engine is run
The only clearance issue i'v got is gearbox to lower brace, but it is bigger cable change box
I'v used complete wiring from a corrado including fuse box which i'v relocated to driver side
But if you got 1.8 gti to start with it is not complicated to addapt
