Help please
(In Topic #144507)
Help please
1) My temp gauge is going hight and red light coming on but the cars not over heating and fan kicks in at resanoble time on stand still, its a 16v top fill rad.
2) My window wipers work only when the stalks in the off postion but when its in the on posstion 1,2 and 3 the battery light comes on and no window wipes????
1.8t Agu this is on
2, wires and earth checked?
JonP said
1, what sensor and wires are you using?
mk4 golf sensor i believe
spent all day on it wire checking nothing has changed since it was last working we have lost the throttle body and now the live feed to the fuel pump wipers working ok now i suspect the fuse box is on its way out to many loses and again without and changes on the loom ect
JonP said
got to use a mk1 sensor in the rad, otherwise i think there is a mod with a resistor to get the temp to sit right.
The rad has the orig sensor in it but the pipe work has the mk4 one in it i believe something i need to double check
if its the later agu then you can cut the plug off and splice the mk3 one on
2. check the main fusebox earth, on the D plug theres a brown wire coming in from the engine loom thats the wiper earth, and theres a second brown wire hanging off the back of the pin thats the main fusebox earth. it should plug into the white 4 way jumper block on the main lighting loom earth
rubjonny said
1. if its an early agu with the large square temp sensor plug i believe the mk3 golf 1.8-2.0 8v sensor is the right rating for the ecu, if so this will work your mk1 dsh gauge perfectly
Is it the 2 pin or 4 pin temp sensor???
sorted the wipers but got bigger problem now as the throttle body wasn't working i decide to take the cover of the ecu and there are bit pop on the bored
if you have 2 sensor flanges then even better, just add a mk2 golf black 2 pin sensor and run your dash temp to that instead
rubjonny said
4 pin one in the side flange
ok cheers rj :wink:
But there is one with a blue band not yellow any tell me if this will work jr
the 2 part numbers in the ebay link are for the mk3 temp sender, so use both of those when cross referencing. the 357xxx number is the original part number, 6u0xxx is the superceeded part number
boom for your temporary bodge:
BOSCH Coolant Temp Sensor Data -Comprehensive CTS (ECU/Gauge and pinouts) - ABA, Corrado, 1.8T s | VW Vortex - Volkswagen Forum
rubjonny said
the wire colours arnt quite the same no, but the pin numbers are the same mk3/4 if you still have the old plug
perfect thank you rj
