HELP!! mk1 golf g60 conversion trouble
(In Topic #76228)
Dave
http://www.matey-matey.com/golf_gti_g60.shtml
This may help you out.
I would guess that the engine should fit straight in, as the G60 lump is also a 1.8 (not 100% sure though).
Other than physically fitting it under the bonnet, you should be ok, except maybe for the wiring which may cause a few problems.
How much experience do you have in this sort of thing?
thanks
If you're not familiar with VWs though, I would recommend getting the Haynes "Restoration Manual" for the VW Golf - this is based almost entirely on the Mk1 and is supposed to be the best.
There's also a guy on here called bens_cab who is doing a 1.8T conversion on his clipper - he may be a good contact as he has the same type of car, and he's offered advice before on it to a couple of people already - check out this thread…
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=4534
HTH
Rich
