help from kr 16v/r1 carbs converts
(In Topic #125214)
Wheres the best place to get filter for carbs like the ones on tuk customs white mk1?
What do you do about crankcase breather? Can you just put small filter onto it?
If you run R1 carbs i take it your using fuel pump, if so do you also use R1 fuel pump relay or what have you got running pump?
And last but not least, do you advise getting external oil cooler or just stick with the one thats on?
Thanks in advance.
