h + h ignition solutions
(In Topic #139298)
have just installed this set up on my mk1 just wondering if anyone else is running this as im having trouble with the master cylinder and servo
cheers richie
cheers richie
1.8 16valve mk1 series 2 black. barp!
Seat inca 1.9 sd van
ignition
i ran this on my 16v a few years back and used a pug 205 gti dizzy cap to save space, alternatively i saw a pedal box for sale in the classifieds.
not using the ignition system this time and using the whole ignition system off the pug 205 instead to take advantage of the vacuum advance keeping things simple and much cheaper.
Haha found out yesterday!! Cheers tho. What's made u go to the vac setup I thought the h +h was a better setup?
h and h
sold it when my other engine died, was going to put a torquey 2ltr 8v in but going back to 16v
Hi just wondering did u have any trouble with your ht leads I'm struggling finding the right cap that fits the ht leads
no i went to a motorshop and tried all the 205 gti caps till i found one with push on connectors. they do both types and clip on caps or screw on caps. i had a screw on cap and just forced the clips over the screw lugs lol
gash i know but it worked.
Ok buddy struggling to find out which one doing my heed in
all i can find on the web is this link
http://clubgti.com/forum/showthread.php?t=228143&highlight=pug+205+distributor
Thanks for helping that's all I could find aswell I'm Richie gti on that thread lol I think I've managed to sort it by using a female screw type dizzy and changed the ht leads over to male connections hoping that sorts it
well good luck!!!! hope it works better than mine did!! found that i couldnt get the right advance on the setup they gave me and used to have real bad flat spots mid range.
good luck
good luck
Oh dear I hope not I thought they were ment to be good? Was yours on 40's
yeh a set of 40's sure it was probs my setup and my lack of knowledge to setup. used to be rapid though and i had fuelling problems from my fuel pump and regulator,
urs will be fine im sure
Sure find out soon doing leads at work tonight going to try get the beast running tomorrow aft
thats with the 205 gti screw cap
