golf mk1 engine change
(In Topic #92674)
i just want to know if anybody has put a mk2 1600 in a mk1,if so do i need to change the fuel lines,tank etc? :dontknow:
best off putting this in the mods section but like what engine is it atm ? like big or little block if its a big block go g60 if its a small block g40 quite simple.
but ur question: yeh should be fine is urs a gti or just a 1.6 carb as the mk2 are carbs so would need to lower the pressure with a different tank and pump .
o yeh where bouts in norfolk are ya ? im from suffolk so not to far away if ya need a a hand
g40'd ratter
<div><embed type="application/x-shockwave-flash" wmode="transparent" src="http://w139.photobucket.com/pbwidget.swf?pbwurl=http://w139.photobucket.com/albums/q312/Forgeman/75e604af.pbw" height="120"
