getting big power out of a 1.3?
(In Topic #136285)
and so far i have a
1.3 engine
4speed box
lovely WEBER carb
GT cam
ported inlet manifold
Ashley 4branch manifold
and looking for a K&N filter to match the carb
what else can benifit the setup i now have?? and is there any need to change to a different fuel pump?
and what should i do with regards to the exhaust? upgrade it to match the diameter of the ashley 4branch
thanks for any info-
Andrew
just so you know, if you fit tha\t cam you'll need to convert it to an electric fuel pump as the cam has no lobe on it for the mech fuel pump
you might need a pressure regulator but I've heard of a few people just running it on the std in-tank pump as is no problem at all. the alternative is to use some kind of aftermarket fuel pump mounted under the car/in the bay, you would just need to check it can cope with sucking the fuel from the fuel tank without a lifter pump to help it
