getting big power out of a 1.3?
(In Topic #136285)
hi there- im building an engine for my mk1
and so far i have a
1.3 engine
4speed box
lovely WEBER carb
GT cam
ported inlet manifold
Ashley 4branch manifold
and looking for a K&N filter to match the carb
what else can benifit the setup i now have?? and is there any need to change to a different fuel pump?
and what should i do with regards to the exhaust? upgrade it to match the diameter of the ashley 4branch
thanks for any info-
Andrew
and so far i have a
1.3 engine
4speed box
lovely WEBER carb
GT cam
Andrew
Er ditch it and go for a bigger engine!! Sorry mate you can only squeeze so much out of a 1.3 trust me i know!
1.4 abd bottom end would be a nice upgrade.
just so you know, if you fit tha\t cam you'll need to convert it to an electric fuel pump as the cam has no lobe on it for the mech fuel pump
@ mk2stu- its for my mk1 derby,so i can only fit a small block engine-i dont want anything bigger then a 1.3 in that car anyway-a lighter engine will suit it much better
rubjonny
- can i use an electric fuel pump from a 8v gti? think i have one around here somewhere. would it have to be a tank mounted pump or could i fit one into the engine bay??
you would need a complete in-tank lift pump and sender unit from a late cabrio, scirocco or mk3 polo (g40 shape). mk2 lifter pump itself is compatible with MK1 but the sender unit is not im afraid. the under car gti pumps are way too powerful for a carby and would just drown the poor thing
you might need a pressure regulator but I've heard of a few people just running it on the std in-tank pump as is no problem at all. the alternative is to use some kind of aftermarket fuel pump mounted under the car/in the bay, you would just need to check it can cope with sucking the fuel from the fuel tank without a lifter pump to help it
