G60 Mk1 gearbox DEFINITE ANSWER!
(In Topic #116853)
My head is really spinning as I have had so much advice regarding gearbox and clutch options for mk1 G60s.
I am at the stage where I really need a box and want an ease of use/good track ratio performance.
Original box seems to last ok if matched with a decent clutch (Sachs Sporting) but ratios are a bit off.
I really dont mind about the top end performance really but am after a simple easy and reliable setup.
cheers. JJ
Retro Cars - editor
1982 Porsche 944 (track car)
1984 VW Scirocco Storm
1990 Mk2 Golf 16v GTI (track car)
1990 Range Rover Vogue
Member 125 - 2005
I was advised to go for mk3 diesel box but then could not get the correct clutch /spline ratio to suit. so i wasted money going down that route.
I would have liked to go mk2 16v box and retained rod change, but i dont know how long those boxes would of lasted.
I like using my car for 1/4 mile sprints but loose time on gear change due to the set up i use, but overall very happy with general on road use.
1979 mk1 Golf Gti (Dan)
2010 T5 Karmann Colorado
2012 mk6 Golf Tdi convertible
2018 VW Amarok V6
2018 VW Amarok V6
Retro Cars - editor
Retro Cars - editor
Website Manager
It is currently undergoing a 16V G60 conversion, for this an 02j box is going to be used complete with an hydraulic clutch, cable shifter and Peloquin limited slip diff !! Not sure on clutch yet, wether to go oem or something more race bred.
Friend of mine runs his on a mk3 TDI o2o box and thats really good through the gears and has a long 5th gear
83 MK1 GTI G60 85 MK2 GTI 20VT 2004 SEAT ALTEA 2.0 TDI SPORT
Am I correct in thinking that you need to match the friction disc to the input shaft and the clutch/flywheel to the box? Also does the 16v mk2 box bolt straight in without any mods to mounts etc…
Retro Cars - editor
also no advantge of a 16v box over a 8v in 020, as 16v means 100mm drive shafts, closer ratios but too close for a torqie 8v prob, plus you will need a 16v clutch.
sorry for all the questions, just one more… if I am using the 16v clutch wont it have a larger friction plate and therefore be better?
So many options to be honest I may just stick with the 8 valve!
Retro Cars - editor
also you will need a 16v pressure plate and race paddle clutch, the paddle clutch isnt cheap and driving around town will be no fun…
the easy option is go 02A cable change, these are good for over 200bhp, and you can use stock clutch and fly wheel, by using a mk3 16v fly wheel and a VR6 friction plate.
the down side to a 02A is the fact you need 100mm drive shafts from a latter cabby, a 02A block from a mk3 gti 16v or raddo 16v etc, plus you need the conversion engine mounts (if if you can weld make your own, to buy they are about ?150 with a new mount pressed in) then you need the shifter from the donor car too.
fitting is not too bad but it does mean you have to find a way to route the shifter cables either under the car or for the motorsport look in the car.
Retro Cars - editor
that set up worked VERY well in my 130bhp 8v track car at santa pod taking some very serious stick inc rolling burn outs to warm the tyres and full power starts
Retro Cars - editor
