G60 into Mk1 Golf - Easy or Hard?
(In Topic #86142)
Just wondering if anyone has any experience on doing this. How easy or hard is it? Rough price to have a pro do it? I understand you need to move engine mounts etc.
Any advice will be gratefully received!
It depends on which model of Mk1 you've got - you won't need to move any mounts if it's a big block (1.5 engine upwards).
Rough price for the engine alone is ?1k +, and labour on top would be another ?1k at least, so I'd budget for ?2.5k to be on the safe side.
Having said that, it's not particularly difficult to do yourself, and even the wiring isn't that hard, so if you fancy a go at it yourself you could save quite a bit.
If you do go for it, make sure you buy all the associated pipework, intercoolers, oil coolers etc… that come with the engine, as this will make things easier and cheaper.
HTH
Rich
HTH
Rich
so are you saying that if you had a mk1 1.8gti you could easiy just take the old out and bolt the new one in.
would you need to change the gear box as well sorry to hijack thread but im thinking the same
even dream of the idea of a 16v g60
i an either do the job for you or help you out, check out www.mvdevelopments.co.uk
Yes - the engine itself is a straight swap. You'll need to mount the intercooler somewhere, and wire in the ECU (3 wires, or so I'm told).
Gearbox-wise I'm not sure - I think they're the same O2O box, but I'm unsure whether the ratios are the same. Gear Up! is a really useful website about gear ratios in VW gearboxes.
HTH
Rich
The gearbox is different, its an 02A instead of 020. Thus it will have a hydraulic clutch, cable change shift mechanism and the shape of it is different, meaning that it needs different mountings to the Mk1 bodyshell.
You can put an 020 tranny onto a G60 engine but common opinion is that its on the limit of how much power/torque it can handle.
if you uprate the shift rod mechanism and bearing for 1st gear in your standard mk1 gear box it wil handle the power fine. remember the bearing needs to be pre loaded.
simple conversion and lovely out come.
lovely out come now that what i like to hear very intrested in getting lots of info on this onemvdevelopments said
I'm also just about to undertake this conversion (just waiting for the engine to be delivered).
I have also been told that the standard 1.8 box will fit, but if unmodded wont last that long!
I have been told that it's a good idea to use an intercooler from a mercedes sprinter!??!
*****Has anyone done a post on the complete conversion.*****
Website Manager
Hi,
I have just had this conversion done to my Mk1 by Midland VW - very pleased with the outcome !!
This is what they used:-
Golf Rallye Engine, G60 charger and ECU, - Full strip and rebuild of engine and charger, it was already chipped and had the smaller pulley.
MK2 Golf 16V gearbox - this was fully stripped and rebuilt,
Radtec Radiator and intercooler - specifically designed to fit a G60 in a MK1
Supersprint stainless 4 branch exhaust - cast manifold found to be too restrictive - Lambda probe added to downpipe.
16V MK2 clocks - because my Mk1 clocks were knackered and these are easy to get hold of - they take some time to make fit properly though as the mountings are totally different.
It goes in for its 1000 mile checkup next weekend, so looking forward to see want power it is putting out on the rolling road :-)
Cheers,
Ade
Cheers,
Ade
radtec setup is great perfect fit, i would use the mk2 16v box with new seals and bearings, if you need any help or would like me to do the job i am more than willing to just pm or ring :wink:
you won't be dissapointed with the end product
Defo go for the rod change box 0-60 times are awesome.
charge cooler is good instead of a standard intercooler just depends how much cash you've got to burn.
1983 mars red 1800GTi on ATS cups
G60'd, schrick cam, chipped, 70mm pulley, pace charge cooler, rolling road 182bhp 250Nm of torque, 14.50 quarter mile.
Below is the bits I picked up for just under 1K (might help as a price guide):-
Tuned G60 Engine
Removed from a low mileage G60
57k Miles - Clocks and old MOT included for mileage verification
Magazine Featured
Includes:
Recently replaced Supercharger (RS Spec Gas Flowed - emails from supplier to prove)
Chipped ECU
Uprated Pulley (2 - included 63mm & 67mm)
Cone Filter & Jabbasport Heat Shield
Original Airbox with K&N Filter
Cat By-Pass with Lambda Probe
(Please note this is the same length as the standard front pipe so any exhaust will fit)
Lightened Flywheel
Intercooler
Slim Radiator and pacet style thin fan
Rod Change Gearbox
New Self Adjusting Clutch Cable (Same as Mk3)
Full Engine Bay Wiring Loom
All ancilleries are still attached and are included (Starter Motor, Alternator, Power Steering Pump, Etc)
New Oil Pump Installed and bottom end bearings and seals etc
Rolling Road - 200bhp before charger & bottom end rebuild.
Tuned G60 Engine
Magazine Featured
Includes:
Chipped ECU
Lightened Flywheel
Intercooler
Rod Change Gearbox
where you get the slf adjusting clutch cable from?
Its from a mk3. (will check) The list of bits is quoted from the previous owner and is all from a mk2 but should be ok unless anyone knows any different?
some mk2's had self adjusting clutch cables too but there found on all mk3's
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
Yep! it was a mk3!
You know your dubs Jamie!
ive had enough practice matey!!! i get loads of dubs in my work in every shape or form from golf's to the old aircooled beetle's!!, only because everyone knows me as jamiegolf and i love my dubs!!!! i got a mk2 in work tomorrow in for an engine change!!!! nice job for a monday morning!! should be done by 3 o'clock!!
