Fuel tank lines
(In Topic #145011)
Fuel tank lines
Could someone confirm that everything is connected correctly? Engine is KR 16v and fuel tank is from mk1 diesel.
Fuel accumulator:
Center connection to fuel distributor;
Side conection to fuel pump.
Fuel pump:
Big fuel pump outlet to fuel tank;
Bonjo outlet to fuel accumulator side connection.
Gravity valve:
Upper connection to breather
Lower connection to fuel tank.
Feed and return lines:
Left - return linne to fuel tank;
Right - feed line to fuel accumulator center connection.
Fuel accumulator:
Fuel pump:
Gravity valve:
Every thing is corrected right but the rubber hosing won't take the pressure it's only low pressure piping It will split when the fuel system pressureises. You will need a braided crimped pipe
Mk1 golf gti
Mk1 golf gti project View topic: 1982 original Irish GTi - The Mk1 Golf Owners Club
mTDI corrado
Mk1 skoda octavia vrs combi
mTDI corrado
