Fuel Pump Relay? 1.3 driver to 20vt.
(In Topic #151404)
I have a 20vt into my 1.3 driver running a megasquirt ECU. Fuel wise for the electrics what is it I need a mk1 gti fuel pump relay?
Then run fuel pump power to e/14. if you like you can put another wire to e/14 with a male spade and use it to power the injectors and lambda heater like a factory vw installation
you could use a k-jet relay without a rev limiter, as long as you run the rev counter feed to the fusebox. these are more expensive and harder to get (in scrappy) than the trigger relay above.
gsf sell the kjet relay though:
935VG0090 k-jet relay without limiter
I've just brought this…
http://www.ebay.co.uk/itm/280965587342?_trksid=p5197.c0.m619
Is that no good?
