From 1.6 to 2.0 8v what I need
I talk to my mechanic that he says that the throttle body doesn't work or the mass flor sensor is s*it.
I look some throttle body like this http://www.ebay.co.uk/itm/VW-Mk3-GOLF-GTI-2-0-8V-THROTTLE-BODY-AGG-ADY-AFT-/281106040504?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item417339c6b8 and I see that i miss the plug in my throttle body! That's possible?
tonight I take the photo
But i haven't too the plug on my wiring, how this is possible? Pic of the plug on the wiring?
I've one error:
00537 010 Oxygen Sensor Control - Upper Stop Value
Dunno what it's…
have a look at the measuring blocks too, this will show you all the sensor inputs in real time. maybe the coolant temp sensor is reading incorrectly which is causing the ecu to set the mixture incorrect, and the lambda is then trying to tell the ecu to correct the mixture but since the coolant temp is out of spec everything is thrown out?
check for air leaks everywhere as well.
so have you found the plug for the throttle body now?
So,now I've to change the exhaust system… what can I buy it now?
my car at low speeds tugging and struggled to keep the minimum at times and the car is not running well, sometimes she stops at 140km/h and then start to accelerate more slowly.
Yesterday I tried to unplug the mass air flow sensor and the car works great: no rips any problems in acceleration.
Could it be the mass air flow sensor is not working?
