Flywheels ? ??
(In Topic #151505)
this could be causing a few issues if they are LOFL
Or would i be right in thinking all flywheels only bolt on in one postion because of the keyway on the crank there for TDC is always TDC ?
have you got a strobe light as thats the only way to check the timing.
it will also need the co set
mk2 8v gti flywheel will be fine
have you got the isv and module?
