Fitting issues with mk2 GTi seats
(In Topic #73017)
They went in with no problems, only the handle for the forward movement adjustment is on the wrong side and the seats are not adjustable. Anyone know how to sort this out?
I was amazed it was only one bolt to remove to get the seat out! so simple. But does the seat adjust bolt carry the full load of the seat and driver in the event of a crash - Seems pretty small and flimsy?
I'll post a pic tomorrow - i'm very pleased with the change!
'83 Mars Red 1.1 C
Mk1 VW Golf 'c' restoration job....
A common finding this one ! They fit but can't be adjusted. Here's how to sort it out ………….
http://www.vwcaddyforum.com/topic.asp?TOPIC_ID=342
Cheers,
Mark
Anyway here's the before and after !!!
Not bad eh!
'83 Mars Red 1.1 C
1983 1100 C
1983 1100 C
I think mk2 seats are the easy option, i was looking into mk1 gti seats and they are pretty expensive. I mean ?15 for mk2 gti seats - you can't argue with a bargain like that!
'83 Mars Red 1.1 C
Guest user
What mods are required to fit the rear bench? is it straight forward or not - i've heard its very fiddly. . .?
'83 Mars Red 1.1 C
Im sure theres a mint pair just like the originals on ebay at the moment
Cheers, think these must be them. They do look mint, and I got very excited till girlfriend pointed out they are the wrong colour :roll: (mine are blue trimmed, these are black). Would have done Greg though.
1983 1100 C
1983 1100 C
'83 Mars Red 1.1 C
1983 1100 C
1983 1100 C
'83 Mars Red 1.1 C
Re: Fitting issues with mk2 GTi seats
No, if you check the tracks that the rear legs of the seats fit into, you'll see a row of teeth, one of which the legs of the seat engage on, in the event of a serious crash, thus spreading the load that would otherwise be solely on the front adjustment pin.
PS: 5-door and 3-door rear seats are nearly interchangeable, but the two arms that help you fold them don't fit as they are in a different place, depending on the car body. This means that the the bottom part of the rear seat is only held by the central tongue-and-loop affair in the middle, which is not ideal…
'83 Mars Red 1.1 C
Looking at this level of safety features, and comparing them with today's cars (or even my ProconTen-equipped 1993 Audi 80) I just hope that I never have a big crash in a Mk1!
'83 Mars Red 1.1 C
I got the same seats in my mk1 and it was easy to fit the slide adjusters to the other side all you need is the arms from the old seats and mounting braket because if you look at the under side there is a space for a braket to go at the back of the seat frame and hole already drilled at the front just put two small holes at the rear and you can slide you new seats!! would show you how mine turned out but can't get the image to work. how you do it???
If you want to post a picture, its easiest to sign up (all free) with www.photobucket.com, then upload your pics there and under each pic will be the link address to it - in the window on here, click the 'Img' button, copy the pic link after it, then hit the Img button again . Thats it!
'83 Mars Red 1.1 C
