Fitting a 02a gear stick and cables into a mk1
(In Topic #159919)
Hi all,
Im currently in the process of putting an ABF engine with the 02a gearbox, from a seat ibiza I have as a donor car, into my mk. I have taken the gear stick and cables out which are routed along the exhaust tunnel in the ibiza.
How have people then gone to route it in the mk1. I think i'v read somewhere that you cut a hole in the bulk head a feed the cables through, if so where abouts is best?
Also is it as simply as just bolting the stick where you want with the 4 holes or do you need to modify the black box around it or get rid of it completely.
Many thanks
Many thanks
route the cable same in exhaust tunnel. never see a ibiza shifter so dont know what the cable lenght is. you have two options that i know work in mk1. mk4 shifter underneath tunnel. or polo gti shifter above tunner hole drilled just under heater matrixbox. test your shifter underneather what u have and see if there is enought cable to the box
